Yeah will do, I tried to replace the drop arm yesterday and snapped 2 bolts :-( , not a happy man at the momentJordi wrote:Fronts should have a set of longer bolts with them.
Soak the fronts on your SJ with a good amout of WD40 over night as i always shear the bolt when i undo them.
Front Suspension problem!
- TomBod08
Re: Front Suspension problem!
One life. Live it....With a Suzuki
As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
Looking at the rear spring pack it doesn't look like it would even compress, let alone reach the bump stops (how many leafs !!)
Pics to show the calami kit along side MGP one.
- mgp.png (729.87 KiB) Viewed 5238 times
- TomBod08
Hmm it would be a bit awkward wouldn't it, I really need to find someone with a welder reallyJordi wrote:As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
![weld :weld:](./images/smilies/1welder.gif)
Think Dans ironmans are 5 leaf.Darrell wrote:If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
Looking at the rear spring pack it doesn't look like it would even compress, let alone reach the bump stops (how many leafs !!)![]()
I'm not a million miles away if you get stuck. I think the current agreed rate is a crate a day, the preferred currency of cider of course.TomBod08 wrote:Hmm it would be a bit awkward wouldn't it, I really need to find someone with a welder reallyJordi wrote:As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
- TomBod08
Good point I never noticed that, it would of only moved it by about 1/2" thought wouldn't it?Jordi wrote:Think Dans ironmans are 5 leaf.Darrell wrote:If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
I have taken a leaf out of each spring as well, I went on a mile trip with them all in and had to turn back as it was unbearable
- TomBod08
Haha true, I'll have a think about itJordi wrote:I'm not a million miles away if you get stuck. I think the current agreed rate is a crate a day, the preferred currency of cider of course.TomBod08 wrote:Hmm it would be a bit awkward wouldn't it, I really need to find someone with a welder reallyJordi wrote:As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
![;) ;)](./images/smilies/icon_wink.gif)
If theory the axle has not been moved forward. The springs are only longer to allow a greater curve. If you sat the spring side by side with a standard spring the bush centres should line up. The lift spring will just have a bigger curve.Darrell wrote:If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
It does mean under articulation as the spring flattens the axles will move further forward. This can be worked out by halfing the distance of the difference in length between the old spring and new spring.
- Ladaman
- Suzuki Guru
I'm only in Huddersfield. I can help if you want.
