engine mount
- timwilks13
- SCUK Website Padawan
Re: engine mount
I'll throw some up when I've finished work, the left mount will sit about 2 1/2 inches further back than mine I think, but I got my engine aligned with the mounts attached, spot welded them on, pulled out the engine and did a "proper" weld.
Re: engine mount
Ha ha, "proper weld" like it Timtimwilks13 wrote:I'll throw some up when I've finished work, the left mount will sit about 2 1/2 inches further back than mine I think, but I got my engine aligned with the mounts attached, spot welded them on, pulled out the engine and did a "proper" weld.
Re: engine mount
Are you using the vitara engine mounts? If so then on a 410 they will sit below the existing chassis engine mounts.
Either swap to the complete 413 mount set up or cut the old mounts off the chassis and make new ones from scratch with whatever set up you want.
As for the height of the engine, it wants to sit so that the middle of the oil filter is level with the top of the chassis rail.
Re: engine mount
Thanks tim , scottie a thort thats where it would have to sit lyk av got the mounts off the vitara think it would be best using them thankss
- timwilks13
Re: engine mount
Didn't have all the pictures I thought but here are the mounts before I spot welded them' thought I had a picture of the chassis with the old mounts cut of, but I can't find it sorry!
- Left hand mount
- IMAG0063.jpg (1.42 MiB) Viewed 5098 times
- Right hand mount
- IMAG0061.jpg (1.13 MiB) Viewed 5098 times
Re: engine mount
Thanks tim big help i think i will do that , what was the hight lyk on bonnet clearence ,thanks
- timwilks13
Re: engine mount
Plenty of room from the bonnet, I messed up my SU adaptor so had to cut a hole out the top of the bonnet for the carburetor to fit in, and the radiator needed shifting back a bit, but no issues otherwise!
Re: engine mount
orighty good thanks for the help tim
