2013 SCUK weekender 17-18th August @ Wagtail
Re: 2013 SCUK weekender 17-18th August @ Wagtail
Flat bed sprinter has tow bar fitted!
I think i'm almost sorted. Other than the diff and bodywork (its ok, its all non urgent).
Who has access to some decent fire wood (some hardwood that will last)
I have some but not the most space in a SWB with a fastback roof.
Can bring as many pallets as i can fit in the available space.
Pallets burn too fast for fuel. Good for getting it going though.
- Edweird
For slow burning you want actual logs. Depends what you want the fire for. Pallets would do fine for fire so long as you're not planning on keeping it lit for the whole 2 days.
Just like sitting round it semi-comatose at the end of the night and not having to keep feeding it fast burning stuff.
I'll try and get pallets with 3"x3" bearers. May be able to finagle some blocks from work.
- suzukisteve
- Suzuki Guru
some aged hardwood would be ideal. if anyone knows a tree surgeon that would be your best bet. when I used to do tree surgery we had a good supply of aged wood.
pickle power!
- timwilks13
- SCUK Website Padawan
not sure how well they burn but I could bring my mates disco td3 down for the fire?
Would you want to be breathing in discovery????
