vitara pas conversion steering shaft problem
Re: vitara pas conversion steering shaft problem
The only part I modified though was on one side only and the tab was welded previously to the original clamp anyway I don't think they'd ever be able to tell in all honesty as the welds are top notch!
Does look a tidy job, just thought I'd warn you. TBH I doubt a tester would even notice
True,thanks for the heads up though Scottie! Only thing is about this though is it still hits the bloody chassis! Re-working of the wedge was inevitable it seems!
