did you know you can get 2 gallons (10 ish liters) of water in a condom.
tony
Waterproofing
Re: Waterproofing
but a condom can be used for other things... what else are you going to do with marigolds? the washing up??!
Re: Waterproofing
do people actually get problems with water. ive fully submerged my engine on quite a few occasions and never had a problem. spluttered a couple of times but not even enough to really affect performance
Re: Waterproofing
Its one of those things with petrol engines, some of them are better than others, i only ever gloved the coil on mine to protect it from any spray and it was usually fine as the dizzy's are pretty high up and out the way and as long as the seal is good they dont let much water in. having good HTleads helps too old ones dont like water thats what happened below
Re: Waterproofing
Scott wot are u wearing in there
Re: Waterproofing
it was a fancy dress offroading weekend fundraising for macmillan cancer nurses so my mate and i were dressed as clowns quite appropriate me thinks
- w1ldstar
Re: Waterproofing
thanks for that,
Rubber glove it is then
Nice pics scott, look like you was having fun there
Suzuki Vitara - 1.5" Suspension lift, Bits4Vits Recovery Bar, Roof rails, Steel front diff.
Drives Shafts broke to date: N/S = 1 - O/S = 0
Re: Waterproofing
I was there but then i had to get it home!!!! managed to find someone with some spare HT leads and then had to drive 60miles+ home with the clutch seized on thanks to that hole!
