Calmini Drop Pitman Arm
Famerbennie
Post by Famerbennie » Sat Jun 22, 2013 10:38 pm
Got SPOA With A ZBar Is It Worth Getting One Of The Above?
Re: Calmini Drop Pitman Arm
Post by Tramp » Sun Jun 23, 2013 7:30 am
I'll be honest I have a calmini drop pitman arm on my SJ with a 3.5" lift and its just about perfect, if I had spoa is be considering the Mercedes high steer conversion, I just don't think the drop pitman will be big enough
Post by andyrew » Sun Jun 23, 2013 11:04 am
Robb storr over the top kit? Id have thought that would be best with spoa.
Boyes
Post by Boyes » Sun Jun 23, 2013 11:17 am
Instead a z-bar, I would use a calmini drop arm & merc high steer. This would enable you to use standard drag bar & reduce maybe even prevent bump steer induced by z-bars.
