Rear drum leak
ferris
Rear drum leak
Post by ferris » Sun Oct 04, 2009 6:27 pm
More problems im afraid. Just noticed some sort of oil leaking from the rear drum. Dont think it brake fluid, cause im still alive! I can only assume its the diff oil.
Any ideas would be appreciated.
Re: Rear drum leak
Post by ScottieJ » Sun Oct 04, 2009 6:56 pm
its more than likely a rear wheel bearing going, meaning the oil seal has failed. jack that wheel up and i bet there will be play in that bearing! its an easy job to do! have a look in the DIY section 8-)
Henry
Re: Rear drum leak
Post by Henry » Sun Oct 04, 2009 8:30 pm
What does it smell like?
Might not be the bearing, could just be the seal, but while you are in there you may as well do the bearing.
Henry
ferris
Re: Rear drum leak
Post by ferris » Sun Oct 04, 2009 8:53 pm
Cheers guys. I did give it a sniff, thought it smelt like transmission fluid but it difficult to tell. As long as its not life threatening il add it to my to do list. Its turning into quite a long list now :lol:
4eye
Re: Rear drum leak
Post by 4eye » Sun Oct 04, 2009 9:19 pm
:lol: there's always a long to do list :lol:
Thankfully mine is a little smaller now..! Will meet up soon matey and have a mud bath. :twisted: :lol: :twisted:
my ride.........:4eye:
Henry
Re: Rear drum leak
Post by Henry » Sun Oct 04, 2009 10:14 pm
Dont let it get too long like mine did.
3 months it took me, and only just finished :twisted:
Both rear wheel bearings where done, not a big job. Hour long job max.
ferris
Re: Rear drum leak
Post by ferris » Mon Oct 05, 2009 10:02 pm
Seems to be a bit more of a problem than i first thought. Drove it to work today and it was making all manner of strange noises, and one of the wheels was occasionally locking up. I think maybe all the oil has fucked up the drum. Dont think im going to drive it until i get a chance to sort it out.
On a brighter note, got my add-a-leaf kit though the post today 8-) :P :lol:
Re: Rear drum leak
Post by ScottieJ » Mon Oct 05, 2009 10:43 pm
defo a wheel bearing then matey! if you need a hand doing it let me know!
d86
Re: Rear drum leak
Post by d86 » Fri Oct 16, 2009 10:00 pm
rear drums i remember those.
while you rae ther convert the rear to discs.
easy job done in an afternoon.
tony :P
