- The Boss
Post
by ScottieJ » Thu Jun 13, 2013 11:24 pm
Buy yourself a set they are cheap
you'll need them for setting the valve lash, spark plug gaps etc.
plus loads of other things.
dazerede
Post
by dazerede » Fri Jun 14, 2013 9:42 pm
Drove it to work this morning and then drove it home at 5.00 and it started first time no probs got it home and then tried starting it but nothing yet so I pulled a spark plug out and there is no spark at all going to have a better look tmoz and plus going to get a feeler gauge
I do hate it when it rains
4” calmini lift kit
- The Boss
Post
by ScottieJ » Fri Jun 14, 2013 9:52 pm
As I said yesterday you need to change the points and condenser, your condenser has broken down and it's always best to fit new points at the same time as its more than Likely burnt the points out.
Boyes
Post
by Boyes » Fri Jun 14, 2013 9:59 pm
Did you have any WD40 (or any equivalent) or easy start they help if you have a weak start, and always got my 410 started when it was cold!
dazerede
Post
by dazerede » Fri Jun 14, 2013 10:04 pm
It starts alright but not today lol
I will order a new condensor and new points tomorrow
4” calmini lift kit
dazerede
Post
by dazerede » Sat Jun 15, 2013 9:52 pm
My zook starts
I bought a new rotor arm and is all fitted
Ordered new points and condensor should be here on Tuesday
Yep just sanded the points down a bit a adjusted it give it a squirt with wd40 and boom it started
4” calmini lift kit
dazerede
Post
by dazerede » Sat Jun 15, 2013 9:55 pm
Also gave it a test drive a worked like a treat just got to put the new parts on
Also got to keep my parents happy as it was in the middle of the drive as I couldn't move it and it is naw in its origional parking place
4” calmini lift kit
