Splitting steering box / arm ball joint
As well as doing the 1.6 swap i'm fitting jimny PS.
How the F' do i get the steering arm ball joint out. Undone/wire brushed the split pin off. Nut came off dead easy but the stud is seized in the arm solid.
Or do i just swap steering arm over?
Re: Splitting steering box / arm ball joint
I use one of these http://www.machinemart.co.uk/shop/produ ... and/clarke
- joint.png (99.3 KiB) Viewed 6295 times
May have to if it won't come apart usuing the usual BFH / crowbar method.
One of these http://item.mobileweb.ebay.co.uk/viewit ... 0918982176 possibly one if the best tools I have ever bought, used mine so much in the last 10 years that I've worn it out
Same kinda tool as darrell has.
Have to get one tomorrow. Be easier fitting the steering box while engine bay is empty.
Darrell beat me too it
but yeah they are worth every penny.
Looks like i'm off to machine mart tomorrow. Cheers fellas.
I tryed everything to try and get mine out and it woulden't budge. It even broke my gear puller. Then i found somewhere online that said you just have to hit it on the side with a hammer. I tryed that and it popped right out
Hit it on the side?
