Thanks mate, I had the glass made by a company called SiteGlass, there based in the South East of Kentliljitjit wrote:wow what a truck! and some of the others in photos arnt to shabby neither!. right enough ass kissing , question for you where did you get your front and rear glass made and were they dear?
Rich
LJ80 Build
Re: LJ80 Build
- liljitjit
Re: LJ80 Build
cheers for , a bit far for me tho, but i take it by the name they are a plant glaziers ? I thought about that route for my front screen . if thats the case i will give my local boys a ring.
cheers.
rich
cheers.
rich
[/color]before you laugh at mine , take a look at your own![/color]
Re: LJ80 Build
Yeah they mainly do big machinery, what have you got SJ?
- liljitjit
Re: LJ80 Build
yes mate i have a samurai if you see othe rpost you will notice i dont have any luck with glass!
just thought plant glazier could cut one to fit and that way i no its a new one!
rich
rich
Re: LJ80 Build
SJ glass is still available mate, you could have it replaced under your insurance
If you have got full comp insurance it should only be about £60
Re: LJ80 Build
well perhaps I should come along when you next go then eh! I just posted a question on raging rhinos about how you do your rear axle & coil conversions as i might end up going down this route now????
- liljitjit
Re: LJ80 Build
lol@ simon , its been sat in the garage for nearly 2yrs! no tax or test and no insurance, hence why need a cheap screen , ill find one soon again i think.
rich
rich
Re: LJ80 Build
Big LJ with all those crazy mods? That has to be Leigh from Dover's work!! (plus I recoginise his workshop when the body is been made wider etc)
Re: LJ80 Build
Hi mate that is one fantastic LJ I want on
few questions with regards to the fitting of the V6, Do you reckon it would fit it in a suzuki sj with out widening the whole truck??
Do the V6 diff's just pop into the sj axles??
What mods are required for the chassis to get the V6 and the gearbox to fit??
The wiring for the V6 was it straight forward or something that I could do?? (im ok on wiring not the best but ok)
Once again what an amazing build!!!
Luke
Luke
Re: LJ80 Build
taz may i draw your atention to this thread.
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =19&t=1448
the blue one hd a 2.9 v6 ford engine on sammy axels.
tony
tony
