Post
by dan_2k_uk » Fri Feb 01, 2013 8:40 pm
dazerede wrote:aww wat that seems a bargin but still u have to make mounts for them
and buy/make
Longer shocks
Longer brake lines
Longer props
Adapt steering link
Bigger tyres
Reduce the gearing to suit tyres
Probably full float rear to handle tyres
Not such a bargain now!
Post
by Jordi » Fri Feb 01, 2013 9:52 pm
I'm in southern ireland for the weekend so won't have internet while i'm there. I'll miss the build updates but i'm sure you'll have the finished shots uploaded when i get back and check again.
Won't you?
Post
by dan_2k_uk » Fri Feb 01, 2013 10:08 pm
Im on call for the next week.
Currently parked in a foot of flood water and sewage cocktail waiting for Southern electric to restore a supply to a pump station.
Presume their transformer is just as drowned so might be here a while!
Post
by dan_2k_uk » Sun Feb 03, 2013 12:04 am
might extend my wheelbase a bit when I fit the YJ's to something like this one.
Would trim the front end to continue out a bit more horizontally rather than come back down in front of the tyre.
What are peoples thoughts/experience on this?
- The Boss
Post
by ScottieJ » Sun Feb 03, 2013 9:00 am
Yjs will stretch the wheelbase a bit anyway, mines got a little stretch in the front and I can still move my rear axle back another 25mm.
You can only really stretch the front upto about 50mm anyway before you need to start customising the steering set up, if you want to go further than 50mm you'll need to swap to a steering box with a forward facing pitman arm and this won't be a direct bolt on and you might need to make a custom drag link as well.
Post
by dan_2k_uk » Sun Feb 03, 2013 9:20 am
Thought the steering might be the downfall.
Seems like a good way of getting back some approcah angle with the longer springs though.
Will have to look at it when I/we start making the kit and see whats possible.
Need the front 8" of chassis rail off one side of a sammy so I can start designing front mounts in the warm and make stuff at work.
dan_2k_uk on Sun Feb 03, 2013 10:46 am, edited 1 time in total.
- The Boss
Post
by ScottieJ » Sun Feb 03, 2013 9:31 am
The only real way of getting your approach angles back with YJs is big tyres
there's only so far you can really go offset from the spring centre pin by redrilling the perches and plates etc.
Problem is doing it with just the front section of a chassis is there is no way to really make sure you get your caster angle correct, I'll give you some measurements to use though after I've reworked mine to work with standard angle perches
Post
by dan_2k_uk » Sun Feb 03, 2013 10:55 am
Just meant to start looking at mounting methods rather than finalise anything.
That pic I posted has its rear brackets on the front springs a lot further forward than yours.
- The Boss
Post
by ScottieJ » Sun Feb 03, 2013 11:58 am
The front of that is shackle reverse so he's extended the chassis quite a bit, it looks like the centre pin is offset? I wonder if its got Toyota springs on the front?
Post
by dan_2k_uk » Sun Feb 03, 2013 12:42 pm
Yjs all round
3 days of callout and my brain is fried and im thinking like a prick.
Moving the spring does naff all as the front of it ends up further forward too. Im a knob head.
Best bet is move as far as perch will allow and big tyres like u said.
Love the look tho!
