fuel tank can any 1 help?
damo
Post by damo » Thu Jan 31, 2013 9:56 pm
does any1 know how many liters my sj413 should hold as it can be empty and i fill it up but it will only take £20 to fill to brim wich is roughly only 15 liters. and also when its brimmed the fuel gage only says its half full any help would be much appreciated
Re: fuel tank can any 1 help?
Post by ScottieJ » Thu Jan 31, 2013 10:09 pm
I think it should hold around 35litres if I remember correctly? Has it been dented as that will reduce the capacity?
damo
Post by damo » Thu Jan 31, 2013 10:12 pm
yes but only slightly i would say it may take 2 or 3 liters less than it should do
Post by Darrell » Thu Jan 31, 2013 10:28 pm
Strange :er: :er:
Workshop manual says 40l
Average price today for unleaded £1.343 = £53.72 to fill from totally empty
I fill mine up at reading 1/4 tank and costs about £40.
Post by Darrell » Thu Jan 31, 2013 10:35 pm
Basically your fuel gauge or sender or wiring is faulty. When it reads empty you must have half a tank left.
My gauge hardly ever goes over 1/2 tank when it's full but at least seems to read correct when lower!!
I just do about 160 miles then fill it back up, I'm too lazy/cheap to find out what wrong with mine.
Post by Darrell » Thu Jan 31, 2013 10:51 pm
The most likely culprit would be the tank sender but to check this properly you need to remove the tank and then the sender and then check it's resistance values at the appropriate heights/levels.
More work than I could be bothered with as I expected nothing to come undone or snap off.
sender resistances.jpg (71.18 KiB) Viewed 7582 times
Post by donkeychomp » Thu Jan 31, 2013 11:19 pm
Is it a standard fuel tank or has a pervious owner put a smaller tank in it's place?
Post by donkeychomp » Thu Jan 31, 2013 11:20 pm
pervious? I blame Jack Daniels...previous.
damo
Post by damo » Sat Mar 09, 2013 10:15 pm
ive had it run out of juice now lol i let it go to empty thinking i ust have half a tank left and i got about 5 miles down the road and he conked out
Post by Darrell » Sat Mar 09, 2013 11:02 pm
damo wrote:ive had it run out of juice now lol i let it go to empty thinking I must have half a tank left and i got about 5 miles down the road and he conked out
Sorry about that :oops:
Right then, I can only assume half a tank reading is correct. So why can't you get any more fuel than that in it :er:
I can't think of any reason :S :argh:
