hi
im struggling to work out how to add an avatar pic, can someone help?!
cheers
tom
avatar pic trouble
Re: avatar pic trouble
The setting is in the user control panel.
Resize a photo using http://www.shrinkpictures.com/create-avatar/ and upload it there.
<<<<<<< job done!!
thanks Dan
thanks Dan
<< Yep..Thanks Dan
Hi mate, i see you are in wolvo? im pretty local to you, where do you go off roading and do you do any local green lanes?Newtomud wrote:<< Yep..Thanks Dan
tom
Hi Tom.. There's a few green lanes around Hampton loade.. Some can be done in any 4x4 but some have made hard core offroaders turn round.. I quote "After a quarter of a mile of steep downhill descent,this lane is joined by a brook to the right,which under normal conditions will do more than get your tyres wet. But the deep wash-out that has been carved down the lane shows it can get a bit tricky in very wet weather,when floodwater rushes down the hill. The LRO team encountered that situation when we explored the lane in 2007 and turned back rather than risk getting stuck" .. Have a look at the ordinance survey landranger 138 map for the area. There all marked on there.theboy wrote:Hi mate, i see you are in wolvo? im pretty local to you, where do you go off roading and do you do any local green lanes?Newtomud wrote:<< Yep..Thanks Dan
tom
P.S. I did it in the little Suzuki
