recovery points ?
Re: recovery points ?
Post by ScottieJ » Fri Jan 18, 2013 10:12 am
and always use rope that is rated less than the shackles and tow points. better for the rope to break than something that could potentially kill you as it's flying through the air.
duncslow
Post by duncslow » Fri Jan 18, 2013 11:27 am
Cheers for the advice folks, going to have a look at the flat bolt on plates. Ive got a piece of 15mm thick steel that I reckon I can cut something out of.
regards Chris
