-Bradders-
![Got muddy boots Got muddy boots](./images/ranks/rank1.png)
Post
by -Bradders- » Thu Jan 10, 2013 9:16 am
I wonder if anyone can help..
As you may have known i didnt have a driveshaft in the drivers side on my fatboy vitara.. however the part that locks into the transmission side, but last night i put in a driveshaft.. works a treat in 2wd low, 4wd low, however 4wd high works but i seem to have lost 2wd high? although... i knew this worked when i bought it, but... i've not used it since the day i got it so it might not have anything to do with the driveshaft, but why would i have every other gear just not 2wd high? i mean i can put it into the gear, but when i put it in 1st gear and accelerate, nothing happens?
Any advice?
Thanks in advance
![:) :)](./images/smilies/icon_e_smile.gif)
- The Boss
![The Boss The Boss](./images/ranks/rank11.png)
Post
by ScottieJ » Thu Jan 10, 2013 9:36 am
Ermmmm
You shouldn't have 2wd low??? The transfer box should only have 2high, 4high and 4 low unless it has been modified.
If you pop the shifter off I have found some pictures of where the selector forks should sit in each of these, If you manually put it into 2high then put the lever back on, hopefully it might sort it.
2high
![01.JPG](./download/file.php?id=6541&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- 01.JPG (45.92 KiB) Viewed 6563 times
4high
![02.JPG](./download/file.php?id=6542&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- 02.JPG (42.16 KiB) Viewed 6563 times
4neutral
![03.JPG](./download/file.php?id=6543&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- 03.JPG (48.35 KiB) Viewed 6563 times
4low
![04.JPG](./download/file.php?id=6544&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- 04.JPG (49.05 KiB) Viewed 6563 times
And the one you shouldn't be able to get into with the standard set up 2 low
![05.JPG](./download/file.php?id=6545&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- 05.JPG (44.83 KiB) Viewed 6563 times
-Bradders-
Post
by -Bradders- » Thu Jan 10, 2013 10:37 am
Place face palm image here * * Lol
I could have sworn it drove in 2wd high/low before haha! maybe its just me being a doofus. i'll deffo have a look though! i got a little gear lever and a light that tells me when im in 4wd but its got 4 positions and when the 4wd light isnt on i assumed its in 2wd, so at the bottom i assumed its 2wd low then one step forward its 4wd low, then across and forward was 2wd high and then forward more was 4wd high... its the previous owners fault. he's replaced all the gear levers with some chavvy blue chrome handles so i cant tell which is which lol.
Thanks for your help!
Ps your pics aint working for me :(
- The Boss
Post
by ScottieJ » Thu Jan 10, 2013 11:30 am
Odd? I can see them ok?? Edit: I can't see them on my iPhone but can on the pc.
This is the standard shift pattern (can you see this?)
![Vitarashiftpattern.JPG](./download/file.php?id=6540&sid=32bec66e1e8fec65b0bd82f51b40dfda)
- Vitarashiftpattern.JPG (4.87 KiB) Viewed 6574 times
-Bradders-
Post
by -Bradders- » Thu Jan 10, 2013 1:07 pm
Explains alot! wow i feel stupid!! thanks for that Scottie, much apreciated
Ricky-410
![Engaged 4wd low Engaged 4wd low](./images/ranks/rank2.png)
Post
by Ricky-410 » Thu Jan 10, 2013 1:10 pm
I can't see them on my laptop either scottie, can only see the one you put as an attachment.
-Bradders-
Post
by -Bradders- » Thu Jan 10, 2013 1:18 pm
Its fine, looking ast that picture i have all the gears i need lol, i just thought it was the opposite was round i thought low was at the back and high was at the front
- The Boss
Post
by ScottieJ » Thu Jan 10, 2013 1:18 pm
Ricky-410 wrote:I can't see them on my laptop either scottie, can only see the one you put as an attachment.
I just saved the pics and added them as attachments instead
