su carb help!!!!
su carb help!!!!
got my su carb fitted this morning but seeing as i have a eletrical fuel pum cant find anywhere to put the fuel return pipe has anyone else had this problem is there a way around it????
cheers jake
cheers jake
Re: su carb help!!!!
As I understand it the electric fuel pumps regulate the fuel pressure and therefore don't need a fuel return.
but how am i guna to stop it on the carb as it just pisses it out everywhere?
- turbo-tom
if it pisses out were its not meant to block it up with a bit of hose, jublee clips and a bolt
Tom
Ford Fiesta ST
Ford Fiesta ST
but wont the pressure build up in it?
Sounds like the needle valve on the float bowl in not shutting. If this happens fuel will come out the over flow pipe.
What pressure fuel pump are you using, as it should be quite low, only 3-5 psi I think.
thats the pipe i was on about the overflow pipe lol unsure on what presure fuel pip i am using but its a suzuki sj413 samurai sport
Exactly what Darrell said. Either valve not shutting to too high pressure pump fitted.
So how could I go round this?
can anyone shine light on it as need it on the road for christmas
