fitting a su carb
fitting a su carb
ive picked up a su carb conversion inlet manifold, adaptor plate and the carb but i was just wondering would i get away with using my inlet manifold or do i have to change it
and any other helpfull tips while fitting would be gratefull
cheers jake
cheers jake
Re: fitting a su carb
Is it a modified manifold to bolt an Su straight onto or does it have the 90* elbow adaptor?
You got a pic of exactly what you've bought?
this is the one ive bought
http://www.ebay.co.uk/itm/Suzuki-Sj-Su- ... true&rt=nc
As it has an adaptor I don't see why you can't use your manifold. Saves you some work.
You just need to fit as it is on the manifold now.
- $(KGrHqV,!hMFC)Lu7NgkBQue+Fy(5g~~60_12.JPG (86.4 KiB) Viewed 7527 times
- $T2eC16RHJHgE9n0yFl6hBQue--ZbCw~~60_12.JPG (114.57 KiB) Viewed 7527 times
To use your existing manifold you will need to cut or file some material to open up the 2 holes to make one oblong hole.
Dan
Dan
As said. Your manifold will have two holes. Needs cutting out into one big whole.
No reason why you cant use your manifold. Or swap the whole lot. Time wise and cost i'd say 6 and 3 2s.
Do you have to make those 2 holes into 1 oval ???
"Bummer", more work then..
O yes...
I'm getting old, It must be my memory going
http://www.suzukiclubuk.co.uk/diy/15-en ... conversion
A gasket for the SU might take some hunting for whereas you can probably just walk into the nearest good motorfactorand get one for the manifold. Gunna need coolant if u remove manifold though so like said its 6 of 1 half a dozen of other.
Dan
Dan
Gaskets are dead easy to get for both ebay or motor factors. I usually just buy a sheet and cut my own.
