Greenlaning gear
Greenlaning gear
So I finally got 2 more AT tyres to match the rears (had roads on the front when I got it), and I plan on starting to explore the greenlanes in my area.
The zuke's completely standard, so no winch, and I'll either be going solo, or with a friend who rides an enduro bike So no assistance available!
So I'm looking for advice on what gear I should have incase I get stuck?
Currently thinking at least a hi-lift jack, a pair of small waffle boards and a shovel.
Anything else that is either necessary or potentially extremely useful?
Found this guy who looks to have a great range of stock;
http://recce-gear.moonfruit.com/
Re: Greenlaning gear
Kinetic rope with decent shackles and some proper recovery points not the standard tow points
Waffel boards are a good call and if you're getting the hi lift get a winching kit with it and a tree strop so you can use the Jack as a handwinch, as said you need decent recovery points front and rear, but safety in numbers is important too be careful if your out on your own matey
I did hear you can use a high lift jack as a winch, so I'll get the winch kit as well then:
2m 14t Tree strop, 4m 5t extension strop,
8m 5t Extension strop, 2 3.25t Shackles,
Leather gloves, Kit bag
And a couple of extra shackles to make 4?
And I won't be trying anything too challenging if I'm the only car out, just want some extra security incase I end up bogging a wheel down...
Don't think a kinetic rope will be of much use to me at first, although it would be hilarious to see a motorbike attached to a stuck SJ with a bungee chord then accelerate away...
But I see you're in Sunderland? I'm in Newcsatle, you ever out greenlaning nearby?
Yeh m8 out most weekends, just came back from drum clog in Scotland. I'm in the middle of a 1.6 vitara engine swap at the min once I get sortted have a dodge out. You tryed pea farm pay and play
Not tried it yet no, as I say, only just got the AT's I needed, but i do want to try it out, is it open every weekend?
Few burly passengers will do the trick if you are out solo
yes its open every weekend.
- turbo-tom
i like going redneck style because when you go prepared its boring but i take this kit anywhere i go!
1.mars bar and can of coke
2.various strops n shackles
3.mobile phone
4.cb radio
5.gloves
6. various sizes of ratchet spanners
7.socket set
8. big hammer
9.little hammer
10. wd40 (must have )
11. gaffa tape n few zip ties
12.old rags
13. rated and tested bow shackles
14.and strops etc
and 15 the most important thing ever ..
think thats it
3.mobile phone
4.cb radio
5.gloves
7.socket set
8. big hammer
9.little hammer
12.old rags
14.and strops etc
think thats it
Tom
Ford Fiesta ST
Ford Fiesta ST
