Could you please tell me which carb this is please?
slaterfett
Post by slaterfett » Fri Aug 24, 2012 7:50 pm
Hi folks, first post. Could someone please tell me if they have a carb like this on the SJ. Basically The samurai i bought had this carb fitted, but the engine will not tick over and I'm finding it hard to located where everything should go
Checked all electrics and put a little fuel straight in the carb and the engine ticked over. Looks like the jet is blocked or knackered
Part numbers on carb are: AISAN 8F25
Thanks in advance
I'm a stinking thief don't buy parts off me!
Jay18
Re: Could you please tell me which carb this is please?
Post by Jay18 » Fri Aug 24, 2012 8:04 pm
Aisan is the manufacturer of the carb, it is the standard carb for the 413/ samurai, but i dont know about what goes where on them as i have a 410 so completely different carb so i cant help you there...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Post by ScottieJ » Fri Aug 24, 2012 8:53 pm
The stock carbs are good when new, but 20 years down the line they are a bit crap to say the least
Here's a clean up guide http://www.suzukiclubuk.co.uk/diy/15-en ... down-guide
If you do that and it still has issues then I would suggest spending a bit of cash on an SU carb and modified inlet manifold to improve the running and power of the engine.
Post by Darrell » Fri Aug 24, 2012 11:39 pm
:welcome: to the club. Pdf file of the carb here if it's any help.
http://www.4x4.in.th/manual_sj413/chapter4.pdf
Post by twiss » Sat Aug 25, 2012 1:28 pm
I always agree with replacing the standard carb. They are a good carb when they work properly but can be a giant pain in the arse if they aren't working. Overly complicated when they dont need to be!
Throw it at next doors dog and get yourself and SU, a weber or a nikki :)
Post by Darrell » Sat Aug 25, 2012 1:52 pm
Give it to me , I'll throw it at my neighbours dogs as there a dam noisy nusiance :argh:
