can you replace this stuff
- dazerede
i think its soundproofing but im not sure its all in the footwells of my sj
- DSC00717.JPG (1.46 MiB) Viewed 10118 times
- DSC00718.JPG (1.66 MiB) Viewed 10118 times
4” calmini lift kit
4” calmini lift kit
- turbo-tom
Re: can you replace this stuff
i recognise it but not 100% sure what it is! , with my truck i ripped out all the carpets soundproofing because they get smelly when there wet and the rot the body sometimes!
if you want sound proofing i would use this stuff but it aint cheap!
http://www.dynamat.com/
Tom
Ford Fiesta ST
Ford Fiesta ST
I would use carplan tetrosyl if you bother to reseal it. A bit smelly but is thick and very much like the original when it's gone off. To be honest I would wire brush it - red oxide paint - chuck the carpets back in.
Click Here for Ebay Listing
- dazerede
i dont have any carpet and was trying to make my zook look a bit smarter
4” calmini lift kit
4” calmini lift kit
- donkeychomp
I found that stuff on my old 410. Used a drill with a wire brush bit and took it all off to find loads of surface rust. Tetroseal and some rust killer took care of it..
I look it all off with a grinder... ruins your disc but hey they're not expensive really!!!
Just chip it off with a hammer and chisel, works a treat, does help if its cold though.
I agree with Scottie, one of the few jobs best done on a frosty day. When it is cold it breaks off in sheets, when warm it is like trying to get thick treacle off your foot wells.
- Ginger_boy
Yep mine came off in sheets along with most of the floor pan. I found that i did get a bit of floor drumming when I had replaced it with new metal. Mine you over the noise the rest of the Zuk makes it was hardly noticable. But the better half complained so I stuck wide bitumin flashing tape to the floor seemed to work, mind you was in the dog house after using her hair dryer to warm the tape up so it would stick properly.
- Edweird
If you're worried about soundproofing, get headphones.
