more miles
covenanter
more miles
Post by covenanter » Mon Apr 02, 2012 9:42 am
hi folks i am a newbie here i run an sj413 as my only car ,i fitted an electric fan and put su carb on it. its a tin top almost rust free.i find it a thisty beast on the road. if i removed a prop when i was running on tarmac .would i gain any more miles.
Highlander
Re: more miles
Post by Highlander » Mon Apr 02, 2012 10:00 am
No, wouldn't help, what sort of mpg are you getting?
I assume you are running it in 2wd on the road?
Do you have manual freewheeling hubs? are you disengaging these when on the road?
Re: more miles
Post by twiss » Mon Apr 02, 2012 10:22 am
I would check that the SU is all tuned up correctly, and has the correct needle and spring in it.
Mine was very thirsty before I gave it the right needle and (especially) the right spring.
Now, mines not too bad on fuel! Although I find it better with the 1.6 cos you don't have to rag it to go the same speed ;)
Removing your front prop would definitely save you fuel but its not really recommended...
As highlander says, I would invest in some free wheeling hubs if you dont already have them.
When they are set to "free" this has the same effect as removing the front prop, and the front diff and shafts.
(Also means you can still drive home if you bust your front axle ;) )
Re: more miles
Post by Edweird » Mon Apr 02, 2012 6:22 pm
As above, get free wheeling front hubs and leave the shaft in, so that if ever you need it, it's there.
An example would be; once at a friends house, I drove into his bin (which I do every time I visit, it's a bit of a game), but on this one occasion I reversed into it. The bin went under the bash plate that protects the fuel tank and lifted the rear wheels off the ground. If I hadn't had four wheel drive I'd have had to tow it off.
covenanter
Re: more miles
Post by covenanter » Tue Apr 03, 2012 11:45 am
Highlander wrote:No, wouldn't help, what sort of mpg are you getting?
i am running in 2wd on road.reckon i am getting about25 mpg. andi have free wheel hubs still to be fitted.what kind of mpg should i expectwhen hubs are fitted.i use it for everyday use ,and i somtimes tow a 17 ft boat with it . it tows it no problem.the su i fitted had come from a morris marina and i changed the needle to new 1300 one cheers covenanter
Re: more miles
Post by twiss » Tue Apr 03, 2012 11:55 am
It might be worth changing the spring as well, it made a massive difference to mine!
You can get them from Burlen Fuel Systems and you want a red spring. They are only about a tenner I think?
covenanter
Re: more miles
Post by covenanter » Tue Apr 10, 2012 11:05 am
thanks guys for your info and advice .got free wheel hubs on now and waiting for carb spring. covenanter
