Problem is it diff or prop shaft
ebooksgti
Re: Problem is it diff or prop shaft
Post by ebooksgti » Sat Mar 24, 2012 8:16 pm
Ok and will i have to adjust the timing ?
Post by Darrell » Sat Mar 24, 2012 8:22 pm
Not if you have not moved the distributor.
ebooksgti
Post by ebooksgti » Sun Mar 25, 2012 6:59 pm
Well thanks to all your helps i have now fitted my 1st clutch many thanks
Post by twiss » Mon Mar 26, 2012 11:03 am
Wahey, we told you it wasn't that hard! :)
It will be even easier the next time you do one!
That's my philosophy, once you have done it the first time it's dead easy after that!
