- The Boss
Post
by ScottieJ » Wed Jan 04, 2012 11:57 pm
Finally starting to crack on with the SJ again.
I wasn't happy with the 1st shifter set up I made for the twin tboxes so I made my own little linkage for the doubler to give me more room for the SJ tbox shifter. It's not pretty but it works
- IMAG0257.jpg (1.13 MiB) Viewed 6573 times
New shifter positions
- IMAG0258.jpg (1.05 MiB) Viewed 6573 times
- IMAG0260.jpg (1.07 MiB) Viewed 6573 times
Started the tunnel cover
- IMAG0256.jpg (1.01 MiB) Viewed 6573 times
Thought it would be rude not to test fit the new steering wheel, Thanks Tom
- IMAG0261.jpg (1.03 MiB) Viewed 6573 times
Post
by turbo-tom » Thu Jan 05, 2012 9:47 am
glad you got it allright then
Tom
Ford Fiesta ST
- The Boss
Post
by ScottieJ » Thu Jan 05, 2012 11:25 pm
Post
by dan_2k_uk » Fri Jan 06, 2012 12:20 pm
Twin transfer sticks on the sj box and fiddle brakes should make it really confusing.
Consider it an anti-theft measure
chrisj410
- Can I have a tow
Post
by chrisj410 » Fri Jan 06, 2012 3:35 pm
:O that looks sweet man, gonna be a beast
looks fecking confusing tho lol
- The Boss
Post
by ScottieJ » Fri Jan 06, 2012 3:45 pm
Cheers matey, its not that confusing once you get used to it.
And Dan I'm toying with twin sticks for the SJ case, won't be doing fiddles as this ones road legal and there's a bit of a grey area when it comes to fiddles on a road legal motor
id need to fit a second set of calipers to the rear axle as well.
- The Boss
Post
by ScottieJ » Sat Jan 14, 2012 9:22 am
Just been doing lots of the small things recently
Got a new aluminum rocker cover for no other reason than because I could
Cheers Sam16v
- IMAG0280.jpg (1.21 MiB) Viewed 6496 times
Also got one of the mk2 golf headlights in, was a bit of a pain in the ass with the virtual lift, I wouldn't recommend it
- IMAG0286.jpg (990.44 KiB) Viewed 6496 times
rgonzobull
Post
by rgonzobull » Sat Jan 14, 2012 8:54 pm
Works looking good Scott. How much more work have you got to do on the SJ before its back on the road?
LJ80Q
- The Boss
Post
by ScottieJ » Sat Jan 14, 2012 9:26 pm
Cheers Gonzo
Errrrm
Exhaust
Handbrake
Coolant plumbing
Electric fan wiring
Pass side headlight
Dash wiring tidy up- I'm moving the fuse box
SU carb (
Twiss hurry up
Brake master cylinder seal kit, my dad and I plumbed in all the brakes today but we think the seals have dried out
Bump stops
Lower shock mounts all round and front upper shock mounts
Paint
Fit seats
Exo cage
I Think thats it bit there's probably more
rgonzobull
Post
by rgonzobull » Sat Jan 14, 2012 9:32 pm
Well its a nice day tomorrow so you should get it all done! Lol. No seriously, its looking good. Bet you cant wait to try it out
LJ80Q
