I'm not sure if this method will work if you have power steering fitted using a wedge but I'm sure it wont be that hard to adapt it if you do. For this I used the original mounts out of the vitara but with the O/S one I rotated it 90degrees so that it sits in front of the rad because the steering box is in the way. Then I trimmed the N/S mount so that it fits between the rad and the chassis and cut out some tabs to weld to the chassis.
Note how i have trimmed the original mount down
Make some small supports for the top of the rad, I used some 2mm sheet, I also added a gusset to the right bracket.
you need to cut a section out of the bonnet for the rad cap.
I would have a little play and see if you can get the rad into a good position with the viscous fan, however with electric fans you can fit the rad anywhere you want and it will also give you a tiny bit more power from the engine.
There are 2 types of Vit radiator, one is shorter than the other and fits without cutting the bonnet. If you have a scout round ebay you will often be able to get the dimensions. The vit rads will fit with a Jimny power steering box, I have doubts if they will fit with a vit box due to the wedge required. I had 3mm clearance either side with mine.
That's a Vit rad with vit power steering box and a wedge in my picture Tim its very tight, you just need to trim a small bit off the lip that runs around the rad i'll get a pic later to show what I mean.
Well dunno which Vit rad Ive got but from looking at Scottie's pics I would say it isnt as wide or as tall.
I measured the height of the standard Rad from the floor and I'm within 5mm of that height so the bonnet should close and side to side there is loads of room.
The cowling lines up ok aswell (bit tight on the drivers side).
Will have to wait and see when I put the front clip on but if I limit mine on the passenger side to the inside of the chassis rail like the picture of Scottie's I reckon theres easily space for a Vit PAS box on a wedge left on the drivers side.
Dan
Janspeed manifold, LWB Vit vented discs and calipers Build thread -- Build photos -- HLA-Artwork Coming soon: YJs, Trussed axles, Full float rear.
Can someone take a top down picture of their engine bay with PAS. Didnt realise there was an issue with clearing the pump aswell as the box. Wanna make sure I leave enough space for the future.
Dan
