tyres
nathan.stevens
tyres
Post by nathan.stevens » Thu Dec 01, 2011 8:08 pm
got a 2" lift, standard 410 engine/running gear etc... anyone know what is the best tyre size for this set up and what tyres shall i get?
need to be fairly good on road and not too expensive! thanks
Re: tyres
Post by ScottieJ » Thu Dec 01, 2011 9:32 pm
What type of 2" lift have you got?
nathan.stevens
Re: tyres
Post by nathan.stevens » Sat Dec 03, 2011 3:03 pm
only shackles at the moment, mainly because my old ones were knackered and i'm saving for a proper lift kit anyway!
Re: tyres
Post by twiss » Sun Dec 04, 2011 1:54 pm
The option I chose was cutting down the gay extended shackles so they give about an inch of lift, then stuck add-a-leaves in.
Gives about 2.5 - 3 inches lift, and I've got wheel spacers as well
Then you can fit 235x80r15s on with no rubbing :)
Although, it will make it slower so you might want to go with 215s or 225s to keep some of your acceleration
