thrust bearings
bigben
thrust bearings
Post by bigben » Fri Oct 21, 2011 3:48 pm
Right so im changing my clutch on my sj410 (85) and upon removing the clutch the thrust bearing fell out and it seems i have lost one of the retaining clips (little u shaped buggers that go round the fork) so this is my first question where can i get one?
now the new clutch (valeo) is exactly the same however the thrust bearing is different, mine has 2 lugs with a hole for the retaining clip and a big bearing in the front. The new one has 2 thinner lugs that bend 90degrees one has a hole in it with the bearing built in and just a thin ring showing for the clutch to turn on.
Whats going on lol
Re: thrust bearings
Post by ScottieJ » Fri Oct 21, 2011 4:16 pm
Jap and Spanish maybe?
Re: thrust bearings
Post by Darrell » Fri Oct 21, 2011 9:40 pm
Been having a look round to see what info I could find and have saved these diagrams (yay, more diagrams :D )
It appears the early 410 has a different shaft and release bearing.
410 normal.JPG (87.58 KiB) Viewed 4812 times
410 82-84.JPG (122.48 KiB) Viewed 4758 times
Re: thrust bearings
Post by Darrell » Fri Oct 21, 2011 10:21 pm
Suzuki only for the springs I guess.
410 82-84.jpgdr.jpg (109.73 KiB) Viewed 4806 times
bigben
Re: thrust bearings
Post by bigben » Sat Oct 22, 2011 9:09 am
That's ace lads mines deffo an early type looks like a trip to zooki for some clips later and whack it all back on the old bearings fine do I'll just use that then I've got a new bearing if I ever change box
Thanx for the great help once again
