Mixing tyre sizes
Christoff
Mixing tyre sizes
Post by Christoff » Sun Oct 16, 2011 6:28 pm
On a jimny can I have 215/75 /15 on one axle and a slightly different size on the other
These other two just say 195/ r15. So the aspect ratio may be different meanin they might run at different speeds and transfer box might not like it in 4wheel drive mode??
Re: Mixing tyre sizes
Post by twiss » Sun Oct 16, 2011 6:33 pm
No you cannot run different size tyres on the front and the back,
As you say, it will wind up the transfer box and screw it up. Probably blow it up!
You could do it on a *ahem* land rover as it has a centre diff
Post by dan_2k_uk » Sun Oct 16, 2011 6:37 pm
might be ok if you only plan to drive on an ice rink :thumbup:
Christoff
Post by Christoff » Sun Oct 16, 2011 6:50 pm
Well these other tyres just say 195 r15 so they dont say anything about the sidewall
I'l have to measure the diameter and see if it's different.
Christoff
Post by Christoff » Sun Oct 16, 2011 7:57 pm
Anyone got a set of 4 winter tyres for a jimny?
