Safari snorkel
Safari snorkel
Been looking for a snorkel for the 410 fancy one of these
http://www.bits4vits.co.uk/store/snorke ... d_197.html
It says it's for a samurai, Sierra or maruti gypsi I thought they were all 1.3 engines
Will this be okay on my standard 1L 410?
Re: Safari snorkel
Yeah it'll be when it comes to snorkels you only need to make sure that they are not restricting airflow, if its designed for a bigger engine then its going to be plenty big enough
Re: Safari snorkel
Are the air boxes pretty similar? Can't remember lol
Should really go n check the Sammie but thought I'd ask first
Cheers for the quick reply mate
Re: Safari snorkel
The air intake on a Sammy box might be a bit bigger than a 410 one but you can get silicon reducers in loads of different sizes to connect them up.
Re: Safari snorkel
Sweet
Cheers Scottie
Cheers Scottie
Re: Safari snorkel
Had to cut the Jack out but apart from that twas all good, cheers Scottie
Re: Safari snorkel
Nice work, let's see some pics of the fitted snorkel then
Re: Safari snorkel
ScottieJ wrote:Nice work, let's see some pics of the fitted snorkel then
There you go matey
- Highlander
- Can I have a tow
Re: Safari snorkel
£258
Thats usually what I pay for a whole Samurai
- Tramp
Re: Safari snorkel
Easy worth the money, it looks good and is certainly a lot better than some of the home brew contraptions you see, well done it really finishes off a nice looking 410!
