MOT number 2!
Everything that was wrong has now been put right!
However the handbrake mechanisms on the rover 600 calipers have seized due to lack of use (think i last used the handbrake for the mot last year )
So a liberal coasting of wd, and ill wip them off tomorrow and free the buggers up and pray for PASS
Then i just have to tax it, insure it, fuel it and build the 200 winch truck to replace it!
MOT number 2!
- Edweird
Re: MOT number 2!
I wish my handbrake was that good. It failed on it, then passed on retest for me. The other day, I put it on a steep hill while unloading, and I noticed every time I took a crate out of the boot, it moved forward about 2 inches. That's after I adjusted it so that it's just off when the handle's down.
- turbo-tom
Re: MOT number 2!
i think most sj's hand brakes dont work mine failed on it a few years ago it was like 7%
Tom
Ford Fiesta ST
Ford Fiesta ST
- mayhemmiller
- Can I have a tow
Re: MOT number 2!
mine seems to work ok there'e a bit of play in it can rock it back and forth a little with it on
awaiting the next adventure
- Edweird
Re: MOT number 2!
If your handbrake's on the prop like mine, I always figured that was just play in the rear diff. What I do like about that, is because there's no centre diff, when you're in four wheel drive you get a 4 wheel handbrake.
Re: MOT number 2!
Well ive found the problem,
The arms on the Rover callipers are siezed in the off position. Liberal coatings of wd, a block of wood and a lump hammer has them working, but i shall take them off tomorrow and have a good go on them.
I never use the handbrake, i always leave in gear, or just where ever it stops. So i guess with lack of use they have stuck in the off position
- mayhemmiller
- Can I have a tow
Re: MOT number 2!
yeah mine's on prop and yes having all 4 wheels lock is very handy at times especially when using it as an anchor for tree work or rope workEdweird wrote:If your handbrake's on the prop like mine, I always figured that was just play in the rear diff. What I do like about that, is because there's no centre diff, when you're in four wheel drive you get a 4 wheel handbrake.
