MOT number 2!
Henry
MOT number 2!
Post by Henry » Fri Jul 29, 2011 9:21 am
MOT number 2!
Everything that was wrong has now been put right!
However the handbrake mechanisms on the rover 600 calipers have seized due to lack of use (think i last used the handbrake for the mot last year :lol: )
So a liberal coasting of wd, and ill wip them off tomorrow and free the buggers up and pray for PASS
Then i just have to tax it, insure it, fuel it and build the 200 winch truck to replace it! :tongue:
Re: MOT number 2!
Post by Edweird » Fri Jul 29, 2011 5:29 pm
I wish my handbrake was that good. It failed on it, then passed on retest for me. The other day, I put it on a steep hill while unloading, and I noticed every time I took a crate out of the boot, it moved forward about 2 inches. That's after I adjusted it so that it's just off when the handle's down.
Re: MOT number 2!
Post by turbo-tom » Fri Jul 29, 2011 6:59 pm
i think most sj's hand brakes dont work mine failed on it a few years ago it was like 7% :lol: :lol:
mayhemmiller
Re: MOT number 2!
Post by mayhemmiller » Fri Jul 29, 2011 7:03 pm
mine seems to work ok there'e a bit of play in it can rock it back and forth a little with it on
awaiting the next adventure
:mayhemmiller:
Re: MOT number 2!
Post by Edweird » Fri Jul 29, 2011 8:31 pm
If your handbrake's on the prop like mine, I always figured that was just play in the rear diff. What I do like about that, is because there's no centre diff, when you're in four wheel drive you get a 4 wheel handbrake.
Henry
Re: MOT number 2!
Post by Henry » Sat Jul 30, 2011 1:37 am
Well ive found the problem,
The arms on the Rover callipers are siezed in the off position. Liberal coatings of wd, a block of wood and a lump hammer has them working, but i shall take them off tomorrow and have a good go on them.
I never use the handbrake, i always leave in gear, or just where ever it stops. So i guess with lack of use they have stuck in the off position
mayhemmiller
Re: MOT number 2!
Post by mayhemmiller » Sat Jul 30, 2011 11:05 am
Edweird wrote:If your handbrake's on the prop like mine, I always figured that was just play in the rear diff. What I do like about that, is because there's no centre diff, when you're in four wheel drive you get a 4 wheel handbrake.
yeah mine's on prop and yes having all 4 wheels lock is very handy at times especially when using it as an anchor for tree work or rope work
:mayhemmiller:
