water temperature gauge
Re: water temperature gauge
Post by twiss » Thu Jun 16, 2011 12:14 am
I've got one from rhino ray before, and I think my mate ordered his one from suzuki...
Smalljeep
Post by Smalljeep » Thu Jun 16, 2011 8:24 am
is this the right part:
http://cgi.ebay.co.uk/Suzuki-SJ413-Samu ... _653wt_907" onclick="window.open(this.href);return false;
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Post by twiss » Thu Jun 16, 2011 8:57 am
That's the kind of part you're looking for lol
I couldn't tell on exact part numbers... I know there are a couple of different senders but I'm not sure what the difference is.
Maybe Darrell will have a nice diagram...
Smalljeep
Post by Smalljeep » Thu Jun 16, 2011 9:00 am
i know the sender on currently has one spade connector.
Post by twiss » Thu Jun 16, 2011 9:01 am
Yeah I think they both do unfortunately... I know there is a diagram of the different type somewhere on the internet...
I've seen it before..
*Goes looking*
Post by twiss » Thu Jun 16, 2011 9:05 am
At least this has the ohm ratings on it...
Smalljeep
Post by Smalljeep » Sat Jun 18, 2011 1:53 pm
i see europarts have temperature sensors, but i just dont know if it would work?
http://www.eurocarparts.com/car-switch-and-car-sensor" onclick="window.open(this.href);return false;
im going to take out the 52mm gague and give it to my uncle for the tractor, ill put a voltmeter in the empty space.
Post by Darrell » Sat Jun 18, 2011 11:29 pm
Conflicting information on these dam things. Some sites say they use the same, some don't. But clearly they don't or the gauge would work fine. Anyway some info saved..................
But there's more numbers out there :argh:
Samurai 34850-50A00.jpg (26 KiB) Viewed 6785 times
SJ 410 34850-65011.jpg (35.2 KiB) Viewed 6785 times
SJ 413 34850-82001 or 34850-85000.jpg (52.61 KiB) Viewed 6785 times
Vit 1.6 1988 on 34850-82011.jpg (43.71 KiB) Viewed 6785 times
Vit 16v Inj 1990on 34850-82012.jpg (29.57 KiB) Viewed 6785 times
Post by Darrell » Mon Jun 20, 2011 11:01 pm
May be best to get one fron Suzuki. If you give them the chassis number they should know what sender/sensor was fitted in the original engine and therefore match the gauge. They may just give you the part number so you can buy an aftermarket one if their nice.
