Hello Everyone,
I am currently working on a builds section... where you can post your builds, and then users can comment on and rate your builds.
There is a link to the builds section in the top right menu bar...
Or you can click this link:
http://www.suzukiclubuk.co.uk/phpBB3/phpBB3/blog.php" onclick="window.open(this.href);return false;
Build Section
Build Section
Re: Beta Testing: Build Section
Sounds cool, I'm going to have a play tomorrow
Re: Build Section
If you want to do a build thread where the comments are kept seperate from the actual build itself then this is the section you want to use, if you already have a build thread but would like it moved into the new build section let us know here and we should be able to sort it for you
Re: Build Section
I'm starting at the oldest builds first... just because they won't have any updates as I'm converting them!!!
As above, if you want yours converted... just ask and we can sort it out
