Right folks, i got round to doing my handbrake today, I have put a 410 t-box and transmission brake on a samurai, i have got the correct cable and the correct leaver. my problem is, were do i secure the cables outer casing to? when i pull the leaver the whole lot moves so surly the casing needs securing down to create the tension!
Dan
handbrake cable
handbrake cable
- pepe-le-pieu
Re: handbrake cable
HI Dan,
when I modified th sj into the blitz i ha dto change the fixing of the cable too. and i have a tb from a 410 as well.
so above the transfer box there is a cross member. if you put your brakecable along it starting at the hand brake the nuts are going to be near that cross member. you just have to get a L shaped plate, bolt it on the cross member and attach the cable to it.
I get some pics for you in the mean time i made a wee drawing if it canhelp
- untitled.jpg (24.63 KiB) Viewed 7594 times
yes yes i bought it to save the rhino...long time ago
- pepe-le-pieu
Re: handbrake cable
here are the pics of the bracket. you will see on the 2nd pic where the old hand brake cable mounting was. hopeit helps
Re: handbrake cable
cheers pepe thats a grate help!
just gota find time to do it now, and the HUGE amount of welding on the rear arches!
Dan
Dan
Re: handbrake cable
that is a great help
as i is to doing this i have looked at it and tryed to find away with out doing a bracket but its no good
going to have to make a bracket like that
cheers karl
cheers karl
- urbanzook
- Winching along now
Re: handbrake cable
HAY THINK OUT SIDE THE BOX MOVE THE HAND LEVER DRILL 4 NEW HOLES AND BOLT DOWN 10MIN JOB! AND THE HAND BRAKE LEVER IS DIF 2 I USED THE ONE FROM THE DONER WHERE I GOT THE T BOX FROM
- LEVER.jpg (52.91 KiB) Viewed 7479 times
