aaaaah....so that's why i went straight on when turning left
Yeh....a bit of a worry at the time....still,...damage done...well bar this
- right then....as ya can see these are fucked-ed....need new balls but how many as i pulled out 6 and a quite a few bits and where's the cheapest place to order? plus how worried should i be about the mess in there!
- ballbs.jpg (165.98 KiB) Viewed 5336 times
- the bearings inside is in tact but as from the state I'm gonna need new.....!? does any1 recondition these/how much am i look price wise?
- joint.jpg (144.1 KiB) Viewed 5336 times
my ride.........
my ride.........
Re: aaaaah....so that's why i went straight on when turning
nasty sorry mate dont know where to get them. you should be able to get the whole unit second hand
the axel cup i would try and smooth out any rough areas so nothing catches
aint scotty got 1?
aint scotty got 1?
Never good
I've blown up all my spares
the last two i have left are in my front axle! I'll ask my mate if he has a spare when im back form France
i new ther'd be something up but didnt expect a mess like that
on a lighter note my new breaklines will be with me by the wknd
cheers scottie
cheers scottie
my ride.........
my ride.........
if you are desperate you could borrow a CV from mine until you find a new one? or you could just run it without one in and not use 4wd if you need it on the road.
Thats ok buddy......its given me the push i need to start training for the 10k run in a couple of months.....peddle power 3miles crosscountry(big hills in wick
) to work
Im not exagerating but i really did nearly die!!!! im a tad unfitter than i used to be 3 years ago
but its not all bad as i can fiddle with the sj while its on axlestands!
my ride.........
my ride.........
