new to everything
Re: new to everything
(I let kwik fit at it once... only to fit a rear exhaust section... and only because I had a recently dislocated thumb!!!)
never again
never again
howdy sounds like a good truck
i had a mate got a job at kwik fit he knew nothing about cars he was the most skilled employee they had at that branch
- Wispa
yeh i went around some woods and it went pfft to everything i put it through! i got stuck once and that was thick mud that completly coverd the wheels and up to the floor which is 2.5ft, i did eventualy drive out of that took an hour to do so but i had no help from anyone else which im quite proud ofScottieJ wrote: I wouldn't let any kwikfitters near my truck
Sounds like your pretty much there before you start breaking things on a regular basis and will be able to go places bigger 4x4s on 35s can't
Apart from your list of stuff you want the only thing I would suggest is a rocklobster transfer box to drop the low box and sort out the gear ratios.
Rockwatt in the traders section is these guy you want to talk to about that he builds them for a good price and his work is to top quality. All you need to do is send him a 410 and 413 tbox.
Are you going for an internal or external cage?
Scott
ill be making up my own external cage, just need to find some good materials and ill be rolling around all over the place
- Wispa
heres a reduced size clean truck pic as the other one turned out alot bigger than i thought
cheers for the greetings lads
i see that everyone has huge trust in that place then haha
- Fullscreen capture 12012011 183948.bmp.jpg (220.89 KiB) Viewed 6576 times
- Edweird
I wouldn't trust kwik fitters to make me a cup of tea. They'll employ anyone with opposable thumbs and arm all of them with a hammer.
I've never seen someone fit Pirellis to a LR 16' with a sledge before........
- Russ24
- Can I have a tow
hi and welcome..
thats a nice looking sj
another tin top.. i thought they were rare.. clearly im wrong.
bloody hell thats tall.
drip tray easy.. a you could get a skip under there... i thought mine was tall.
- Russ24
- Can I have a tow
i fitted my axles with a crowbar hahaEdweird wrote:I wouldn't trust kwik fitters to make me a cup of tea. They'll employ anyone with opposable thumbs and arm all of them with a hammer.
- Wispa
crowbars on axels.. understandable.. but sledge hammer needed to fit a tyre?!? must be doing it wrong? probs got the tyre size wrong :beat:
- Edweird
Possibly, but it looked to me like he couldn't be bothered to lift the rim onto the machine, as it was the one he'd taken the tyre off first, then taken the other off, rather than doing one at a time.
By the way, he wasn't swinging the sledge, he was using it to push the other side of the tyre on while he stood on the one side.
- Wispa
thats what lever bars are made for
