Lwb Santana 1.3 Hif44
Re: Lwb Santana 1.3 Hif44
I’m working on a little something for fiddle brakes for those of us with road legal SJs
Ooo interesting! I really should focus on working standard brakes before I start trying anything that fancy
- d_r_1989
- Winching along now
Saw the videos, looking good! Got the mot sorted now?
Cheers man! Was good to get out in it. Yeah mot is all good just waiting on v5 coming back. The place. We went is just up the road behind my house so wasn't heading to far.
- d_r_1989
Good work. It's a proud moment when your build gets mot'd and you go for the first drive.
I wasn't being the police and checking up, I'm certainly not one to follow rules, as you can tell from my builds
Really was man, prouder when got it offroad tho
And all good
never know whose watching tho
And all good
- d_r_1989
Nothing but law abiding citizens here
Been ticking away at jobs. Changed my front flexis over for extended ones and I've swapped the ports at master cylinder. Still need to bleed and test. Figure worth trying before cutting a bias valve in.
Also had the tbox out to fit a rockwatt gaurd, cause I run landrover engine mounts on it I've cut some of the floor out and raised it as high as can before hitting seat rails as bolts a pain to get to. All welded and Seem sealed just got to redoxide and paint then can fire it all back in.
Also swapped out my fuel pump as was weeping abit from the bottom hole. Thinking it may be alot of my fueling problems. So will need to change the oil in engine to.
No sign of v5 yet but got a day at drumclog planned for the 18th of may so still plenty time hopefully
So bad news. Dvla have said the car is still registered as permanently exported. So gonna be a long process getting it on road still.
- d_r_1989
Sounds like you have been cracking on! Why are dbla saying that?
