1991 Santana Samurai
Online
Re: 1991 Santana Samurai
Bit more sorting out done.
1. Location of the Volvo electric pump. Ideally to keep power and hose lines short adjacent to the steering box. Does not seem to work at all. So on opposite side fixed to the jack position.
2. Tried preliminary position for auxiliary fuse box.
Online
Busy morning. Jimny steering box fitted, adjacent radiator support fitted with no clash.
Rockwatt inlet manifold fitted together with cooling hoses.
Fitting for relays trial fitted. Start made on replacing all fuel and brake lines.
Online
Trial fix for relay location.
Online
Unboxed the new radiator. Will be fitting a power steering oil cooler to the radiator as well.
Online
My next "design" exercise is to mount the Volvo electric power steering pump.Suitable location is adjacent to the jack platform.
Paper and pencil at the ready will take measurements and see what I can come up with!!
Online
Obtained a WFM bracket / box for the Volvo electric pump. Been measuring / sketching and 'may' have a solution. More later.
Have purchased a set of the rubber anti-vibration bushes as well.
Online
First trial fix still retaining jack position. End bracing still to go in.
Some tweaking needed but in principle it works OK.
Some tweaking and pump in position.
Online
'Final' fix of the Volvo pump. Some paint as well.
Online
As have done rear disc conversion intend to fit a proportioning valve.
Stripped out brake system for complete renewal. Proportioning valve has seen better days.
Online
My 6 way and proprtioning valve I plan to fit.
