http://www.lowrangeoffroad.com/rcv-ulti ... p-rcv.htmld_r_1989 wrote: ↑Fri Apr 03, 2020 8:12 amThats some excellent information there scottie thanks
Yes im planning on running 33s as with the virtual lift i think 31s will be too small.
It has a 1.6 carb engine so hopefully that will help
Are the jimny 4.3 rear diffs rare? Strong as sj diffs?
I have seen your write up on the homemade rocklobster but im not confident i can do the pressing of gears plus i havent sourced a 410 tbox yet. Might just have to fork out and buy a rockwatt made one.
How much are these 26 spline chromoly shafts you speak of and are they worth it?
Transfer box and diff ratio calculations for 33s
Re: Transfer box and diff ratio calculations
Re: Transfer box and diff ratio calculations for 33s
Yeah, same thing, different brand.
Nope it was my bad.... I had 5th gear set to 0.86, Forgot the Samurai box was taller in 5th, I run a vit gearbox and thats 0.86, also early 413 gearboxes were 0.86
Not quite as strong as the RCVs but you won't break them on 33s, well unless you really drive like a knobd_r_1989 wrote: ↑Sat Apr 04, 2020 10:47 amhttps://www.jimnybits.com/sj-samurai/dr ... pline.html
Are these the same just a different brand?
- d_r_1989
- Winching along now
Nearly 3 years on and at the same point with my next build, I find my old thread and it answers my question.
SCUK!!!
just to update for anyone else who finds it in the future, I'v been running 5.12 diffs with standard samurai transfer box and axles. Ratios work really well for 33" tyres with my 1.6 and iv had no breakages (touch wood)
SCUK!!!
