Mikes lwb build and repairs !
Post by Rankine » Fri Oct 22, 2021 7:19 am
It seems nothing is built to last anymore they just want to sell you more. Maybe one day I'll run one.
Well hopefully the new set up you pick last and dosent decide to kill any more shafts or itself!
Post by mike harris » Fri Oct 22, 2021 5:45 pm
Shafts I don’t think will be a problem now, the weak link is unfortunately the diff.
But we shall see !
Post by Rankine » Fri Oct 22, 2021 11:45 pm
Factory welded will be pretty strong 😂 not like you drive it on road, do braw in the rear. Mines only a pain on went road bends
Post by mike harris » Sat Oct 23, 2021 9:41 pm
Event in Devon end of next month need to pull my finger out and do some prepping !
Post by Rankine » Sun Oct 24, 2021 9:47 am
Best of luck man!
Post by mike harris » Sat Nov 06, 2021 9:32 am
Broken 5.38 diff I rebuilt
3.9 Air locker needs finishing but it’s made it into the workshop at least !
Post by mike harris » Sat Nov 06, 2021 9:34 am
I’m still after large diff flanges with the sharp spline design not the flat type !
Post by Rankine » Sat Nov 06, 2021 5:26 pm
Broken again or from a old repair?
Post by mike harris » Sat Nov 06, 2021 7:45 pm
Broke again, I don’t mind as there cheap. Problem is now shafts are so strong that the bit that will fail.
I have a lot of them so it’s no problem, I’d rather that break than any other bits !
Post by Rankine » Sun Nov 07, 2021 8:40 am
Suppose better the cheap slightly harder to get to part than the expensive ones!
