2008 vitara 1.6 misfire when hot
jhwrc
Post by jhwrc » Sat Feb 06, 2021 6:19 pm
Hi all, need some help!!
08 Vitara 1.6 has started misfiring when it gets upto temperature both when idling as well as been driven. When left to cool down seems fine until it seems to reach a certain temp again, before fan cuts in, then misfires again and won't stop until its cooled down again!
Searched everywhere for any similar problems online cant find anything. Took it to garage they replaced egr valve, gave it a road test said it seems fine! Obviously not as did it on the way back from the garage!
Any ideas?
Re: 2008 vitara 1.6 misfire when hot
Post by ROBBIE » Sat Feb 06, 2021 7:32 pm
Has it got coil packs? If so one of them could be on the way out
jhwrc
Post by jhwrc » Mon Feb 08, 2021 6:34 pm
Yes it has, how can I check the.?
Post by ROBBIE » Mon Feb 08, 2021 10:00 pm
Sorry mate I have no idea, all I know is we have a Jimny in the family and that has had the problem a couple of times. I suppose you could try the old way and pull each lead in turn when it’s having the problem
