Starting Issue
border
Starting Issue
Post by border » Tue Sep 22, 2020 10:35 am
Having problem with starting, it does start first time but as soon as key is released it cuts out. Any Ideas ?. SJ 410
rockinsuzuki58
Re: Starting Issue
Post by rockinsuzuki58 » Tue Sep 22, 2020 12:07 pm
my sj410 had same proble twice first time dirty connections on the spade connectors on the coil and cleaned all those and the the plastic multiplug near the coil the about a year later exactly same as yours would only run with the key turn believe it our notcheck you fuses there is a separate fuse on the sj for the ignition not sure which the fuse hadnt blown just a dirty connection jus unplug all fuses and clean them its definately one of those i would stake my reputation let me know what it was tony in 38 degrees cyprus have a nice day
rockinsuzuki58
Re: Starting Issue
Post by rockinsuzuki58 » Tue Sep 22, 2020 12:12 pm
check to see if you have an ignition light if not its the fuse
border
Re: Starting Issue
Post by border » Tue Sep 22, 2020 2:31 pm
Thanks the lights on n dash did suddenly did dissapear. Is it one of the fuses in box on right hand Side ?
rockinsuzuki58
Re: Starting Issue
Post by rockinsuzuki58 » Tue Sep 22, 2020 3:16 pm
yes on the right under dash maybe a dirty connection just keep unpluging each one and plugging it back in and watch for the light coming on mine was just dirty but i repled it let me know thankyou tony
rockinsuzuki58
Re: Starting Issue
Post by rockinsuzuki58 » Tue Sep 22, 2020 3:17 pm
sorry should say replaced it
border
Re: Starting Issue
Post by border » Tue Sep 22, 2020 7:20 pm
You were Exactly right Mate, it was the fuse. Thanks.
Got another problem with engine will post new thread on it.
