the no dosh LJ revamp
- donkeychomp
Re: the no dosh LJ revamp
You just need some thin MDF, use the good card as a template, but in reverse!
Look good alex, what are they wrapped in?
Did you say MDF? Take it you don’t plan on them getting wet?
I have a pair of checker plate cards in the garage somewhere, if you is interested
- donkeychomp
Not MDF lol. I ended up using the original card with a bit of added bracing. Wrapped in vinyl I get from my local hardware shop.
- donkeychomp
Bit of nice weather today so started on the rust. It looks awful but it's all surface corrosion, bit of wet and dry and rust killer sorts it. Yes she's still green as I have a load of paint left over from the Kawasaki! Also started repairing the other door card.
- donkeychomp
- donkeychomp
- donkeychomp
- donkeychomp
