the no dosh LJ revamp
- donkeychomp
Re: the no dosh LJ revamp
Made a start on the inside today, and the number plate light got done too, it was covered in tiny scratches but some fine wet and dry got that sorted. I will be making some panels for both sides and the floor, the roll hoop will probably have to come out to do it properly, might even get that blasted then powder coated.
- WP_20170721_001.jpg (165.31 KiB) Viewed 5974 times
- WP_20170721_002.jpg (156.67 KiB) Viewed 5974 times
- WP_20170721_003.jpg (141.64 KiB) Viewed 5974 times
- WP_20170721_004.jpg (124.42 KiB) Viewed 5974 times
- WP_20170721_005.jpg (177.29 KiB) Viewed 5974 times
- WP_20170721_006.jpg (131.05 KiB) Viewed 5974 times
- WP_20170721_007.jpg (144.08 KiB) Viewed 5974 times
Looking good as always
- donkeychomp
Finished the other side in this so called 'summer' weather. Need to go get some MDF next. And the Pro Comps are all done ready to go on. Also ordered some new brake shoes for the next MOT, matey mentioned they were ok but not brilliant...and I need to do something about those holes!
- WP_20170725_001.jpg (176.25 KiB) Viewed 5950 times
- WP_20170725_002.jpg (152.11 KiB) Viewed 5950 times
- WP_20170725_003.jpg (202.01 KiB) Viewed 5950 times
- WP_20170725_004.jpg (116.56 KiB) Viewed 5950 times
- WP_20170727_008.jpg (168.05 KiB) Viewed 5950 times
- donkeychomp
Bit of routine door maintenance...
- WP_20170801_003.jpg (156.71 KiB) Viewed 5909 times
- WP_20170801_004.jpg (156.89 KiB) Viewed 5909 times
- donkeychomp
Still at it with this door, gave it a coat of primer to see if there were any imperfections. Short answer, yes. Loads of filler later and I'm stil not done!
- WP_20170803_004.jpg (163.59 KiB) Viewed 5893 times
- WP_20170803_005.jpg (146.93 KiB) Viewed 5893 times
- WP_20170803_006.jpg (153 KiB) Viewed 5893 times
- SlimGrim
- Winching along now
Yes dude this looks mint!
___________________
- donkeychomp
I prefer dents Alex.
- donkeychomp
I have a selection of hammers should you require extra dents...
