Does anyone know the pulling power of a Jimny in 4wd low ratio?
Regards Golfinggas
Performance
Re: Performance
As in it's max torque? Weight?
Re: Performance
If it's towing on the road, 4x4 Low cannot be used... and the towing capacity is 350kg unbreaked, 450kg breaked.
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: Performance
According to Suzuki for the latest generation it's 350kg unbraked and, not that you would want to 1300kg braked.zook123 wrote:If it's towing on the road, 4x4 Low cannot be used... and the towing capacity is 350kg unbreaked, 450kg breaked.
4wd low makes zero difference to this. The 4wd system is only designed to be used on loose and slippery surfaces. If used on dry grippy surfaces like tarmac it winds the transmission up and will ultimately cause issues.
Re: Performance
I'd say that was impressive but i've seen a human pull more.
Re: Performance
Mine struggled to pull a Ford Focus along a flat road, saying that, that was on the old engine
