gear changing
scot the sniper
gear changing
Post by scot the sniper » Tue Feb 21, 2017 11:02 pm
hi guys picked up jimny tonight and the gear change is really stiff and hard to get into gear is this a common problem and is there a fix please
thanks in advance
scot
Re: gear changing
Post by Darrell » Tue Feb 21, 2017 11:17 pm
If it selects gears nicely when it's not running, it may be the clutch dragging.
scot the sniper
Re: gear changing
Post by scot the sniper » Tue Feb 21, 2017 11:49 pm
thanks for that it has had a new clutch fitted
zook123
Re: gear changing
Post by zook123 » Wed Feb 22, 2017 8:19 am
When you say stiff, have you tried going from 1st, N, and then 2nd?
Mine does this, I think it's a Jimny trait!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: gear changing
Post by ScottieJ » Wed Feb 22, 2017 10:14 am
It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
I would change the gearbox oil while you are at it.
And make sure the clutch cable is correctly adjusted.
Re: gear changing
Post by ScottieJ » Wed Feb 22, 2017 10:15 am
zook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
It's not a trait......you just need to fix the issue :P
zook123
Re: gear changing
Post by zook123 » Wed Feb 22, 2017 11:09 am
haha, In the Jimny world it is, SJ's maybe not!
Re: gear changing
Post by ScottieJ » Wed Feb 22, 2017 5:57 pm
The Jimnys I've driven have changed gear fine ;)
Re: gear changing
Post by ROBBIE » Wed Feb 22, 2017 6:38 pm
Yep mine isn't like it
scot the sniper
Re: gear changing
Post by scot the sniper » Wed Feb 22, 2017 8:37 pm
ScottieJ wrote:It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
ok how do i know its adjusted properly
