What are these connectors/sensors please?
- villagehoppa
Hi All, apologies for all the question but trying to learn the SJ!!! Does anyone know what these connectors/sensors are? No1, is that a throttle position sensor? It's a 1995 1.3 fuel injected model... What are 2 and 3 for? Thanks in advance all, it's probably really basic engine stuff but still learning my way round!!!
- Connectors.jpg (280.62 KiB) Viewed 4367 times
- Connectors2.jpg (310.4 KiB) Viewed 4367 times
Re: What are these connectors/sensors please?
No that mine is the same setup, but I want to say the second pic is the throttle position sensor, and the first maybe the temp sender, can't really see the pic!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
2 is air inlet temperature. 3 is water temperature.
As Darrel and Dean say
1. Throttle Position Sensor (TPS)
2. Inlet Air Temp (IAT)
3. Engine Coolant Temperature (ECT)
- villagehoppa
Ace thanks for that, Hopefully a new throttle position sensor will sort out the high revs on start up!! You can but hope... Thank all...
