My rough set up is standard 1.3i engine (55Mph max
I am extremely happy with the road performance/stability of it, given that it has dramatically changed from its shock setup but it is almost unbearably hard on the bumps when on the smaller roads (main roads are fine but I live in the heart of Devon and don't see them often!)
I don't use it for to its full potential, I just love the look of it and occasionally cross rivers and play in muddy fields!
Pro Comp (cheap but spent I have all money on the other mods!) do four different models; ES1000(Cellular), ES3000(Cellular), ES6000(nitrogen) and ES9000(nitrogen). The reason I went for the ES9000 is because I thought it would effect body roll when cornering on road (atm, I can go around a fairly sharp corner at 50Mph and it feels solid)
Has anyone else run Pro Comp ES9000 shocks and then changed to others and found it made a difference on road to bumps or body roll?
Thanks in advance guys!
