Help with mods for a newbie to this.
rogsmith
Re: Help with mods for a newbie to this.
Post by rogsmith » Tue Aug 30, 2016 5:31 pm
Steering rack • Slight play
Chassis members • Has patch of rust
Power steering • Slightly leaking from high
pressure hose
Shock absorbers
(conditions/leaks) • Offside front weakness in shock
absorber
Gaiters/boots • Nearside front cv gaiter outer split
Fluid/oil leaks • Oil leak from front crankshaft seal
Shock absorbers • Weakness to front shocks
Exhaust
Operation • Blowing from down pipe
System condition • Corrosion and broken
Additional points of note from the mechanic:
• It has some leak from rear differential
So these are the things that were mentioned after the inspection today.
Post by donkeychomp » Tue Aug 30, 2016 9:30 pm
They ALL leak oil from that crank seal!!
Shocks? No worries as you will be putting on new ones, may as well do the gaiters at that time.
Exhausts are pretty cheap on Ebay, easy to fit too. Why not get a Cherry Bomb as well?
rogsmith
Post by rogsmith » Tue Aug 30, 2016 9:52 pm
Good to know mate. I must admit i am fairly happy with the result.
Time to get started on it.
r-nottz
Post by r-nottz » Tue Aug 30, 2016 10:05 pm
Sounds like a normal Suzuki.
Apart from you dont have a leaking rocker cover gasket. Pretty much every one I've owned leaked from there.
zook123
Post by zook123 » Wed Aug 31, 2016 8:30 am
donkeychomp wrote:They ALL leak oil from that crank seal!!
I found that out! Was stressing about it until Scottie told me to man up!
That doesn't sound like too much of a list, just "upgrade" as you break, that's what I'm doing!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
