I bought this polybush set from bits for vits
As you can see the kit only comes with crush tubes for the larger bushes, does that mean standard leaf spring polybushes don't require crush tubes?
As I'm running a calmini kit, it uses a different arrangement of bushes. I'm using the smaller bushes in the shackle but the crush tube from the large bushes don't fit.
Here is the shackle with the bushes fitted alone
![Image](http://i270.photobucket.com/albums/jj112/natlouise14/Lukes%20things/suzuki%20sj/SJ%20Welding/42200033-E668-4798-BA8A-89F297C0E237_zpscqebfkem.jpg)
And what happens when I try to fit the crush tube
![Image](http://i270.photobucket.com/albums/jj112/natlouise14/Lukes%20things/suzuki%20sj/SJ%20Welding/C9453FE4-7161-491E-AD58-B401E14DA506_zps4ur5aaxx.jpg)
So basically do I even need the crush tubes? Or does any one have a master plan on how to get the crush tube in without the bush pushing out?
