sj service parts
Doghound
sj service parts
Post by Doghound » Thu Feb 25, 2016 7:49 pm
So, i need to fettle and fiddle a sj413 back to the little fella's beastly best
Wheres the best place for service parts?
First off a want an ignition overhaul kit, plugs points, HT leads ect
Cheers.....adam
Re: sj service parts
Post by ScottieJ » Thu Feb 25, 2016 10:32 pm
Your local motor factors should be able to get everything you'll need for a full service.
Doghound
Post by Doghound » Thu Feb 25, 2016 11:04 pm
Ah right cheers, thought there might be a specialist tucked away somewhare that you lads use
Post by twiss » Fri Feb 26, 2016 7:09 pm
Theres a couple in Malta but that's probably not much use ;)
